I am using a PIC18f452I/P with bootstrap loader v1.1
verified.
when i turn on the core the lcd backlight comes on but it doesn’t send the sysex request for mios.Nothing displayed on lcd, but if i turn contrast up I get black boxes. I need to know what to do to get mios loaded.
I have only heard of problems with v1_1 of the bootstrap loader.
Have you checked your voltage levels? Make sure you have a stable 5v, with all pin connections verified as being hooked up correctly. If that doesn’t work, there might be a problem in the midi end. I would initially disconnect the LCD screen from the board until you have found the problem. I have found this to be very helpful when doing troubleshooting.
I have just had a dilemma with a constant reboot problem, and Thorsten had directed me to disconnect D7 and the 5v at pin 2 (contrast connection). It corrected my problem.
I would say for the sake of troubleshooting to do so, to make shure that nothing is shorting out through the LCD connections.
There is only a small amount of things it could be.
1.) Power requirements not stable
2.) Midi circuit is failing
3.) Either the LCD or I/O connections are shorted.
You could also pull up/down I/O’s, and minimalize the circuit, to make sure there’s not a short.
What settings are you using in MIDI-OX (if thats what your using)?
