I plan to use my midibox seq with my sh101 via midi-cv conversion. However, will I still be able to use the 101’s glide/portamento feature? Will I need to install a midi mod for my 101 instead? thanks, --chad
it depends on your MIDI-CV interface. If it provides a special trigger which is activated on overlapping notes (sometimes called “Sus-Key”), then it will work from a common note track - this is the way how portamento is triggered on common synthesizers (mostly it’s a special option which has to be enabled seperately). Alternatively you could also control the portamento effect from a second track via CC
