Hello,
Sorry I bother again, but I had a question about a recent project I’m working on.
I want to create a “sample controller” for my MIDI realisations (articulation switches, kontakt control etc…), I want the project to have a big GLCD
to display the possible articulations, I bought an GLCD based on the T6963 controller (it’s a 240*128) the datasheet can be found here:
http://www.lcd-module.de/pdf/grafik/w240-7.pdf
I connected the module to the core but I only got the backlight lightening up (with the T6963 program running from the download page). Sometimes there are some lines running over from the top to the bottom ???(seems like some interference, because I get those lines when the IIC led’s light up) .
First I wil describe how I connected the GLCD, because of some pin’s I’m not 100% sure:
Data pins are OK for sure
Voltage pins are OK for sure,
Read and write is also logical.
Pin 4 of the GLCD is connected to the CD (RS) pin of the core. (this is ok?)
V0 pin of the core is not connected because the LCD has the possibility to justify the contrast between pin 3 and 17, so I thought pin VO of the core is not needed (is this OK?)
So pin 15 (enable), 16 (reset), 18 and 19 are not connected.
It’s strange that the enable pin isn’t connected in my setup and if I read the datasheet right, the reset pin resets when its status is low (because L: reset). Which means that the LCD is constantly resetting.
On the GLCD website on ucapps I read that there’s a limitation on resolution for GLCDs, so I also wanted to ask if it’s difficult to extend the resolution to 240*128?
Thanks
Best regards
