??? Hi Tk
Just built that flooboard thing for Mackwreck.
Only thing is that it does’nt go !! he he he
As you know I check things and I have checked this.
Upshot is that I get nil per led segment. I guess I should see something on the leds when I power up.
I have not tried to send any midi with it yet, did’nt see the point.
Did anyone build this thing b4…?
Wondered if there might be a code prob or something.
BTW can the 877 be used ?
TIA Ian
:-[ Ok so do you think 33,000 pf is a bit toppy for the oscillator !!! :-[ :-[
Now the leds light up ok. Thing is the numbers appear to be changing but all the leds segments are all bright and the ones displaying value are only marginally brighter.
Ideas ?
Ian
So TK
I bet that’s the sort of result you would expect from a common cathode segment is’nt it !!?
Ian
Things are getting real bad when you post replies to your own posts.
The other day I had an argument with myself and lost :o :o :o
Oh how delightful the leds are when it boots up :
Those stinky segments were CC not CA. Slid the new ones in and it works a treat.
Now gotta work out how to change the source code …eek ???
Ian
T.K
January 28, 2003, 1:11am
6
Hi Ian,
the source code mod is easier than resoldering all the parts (ok: for myself ;-))
In irq.inc, you have to exchange the LED routines:
;; LED subroutines for timer handler
LED_Set0
movlw 0x01 ; Digit 0 on, Digit 1 off, Digit 2 off
xorlw 0x07
movwf PORTC
movf LED_DIGIT0, W
goto LED_SetDigit
LED_Set1
movlw 0x02 ; Digit 0 off, Digit 1 on, Digit 2 off
xorlw 0x07
movwf PORTC
movf LED_DIGIT1, W
goto LED_SetDigit
LED_Set2
movlw 0x04 ; Digit 0 off, Digit 1 off, Digit 2 on
xorlw 0x07
movwf PORTC
movf LED_DIGIT2, W
; goto LED_SetDigit
LED_SetDigit
;; First: Check Flash Flag
IFCLR LED_FLASH_FLAG, 0, goto LED_SetDigitCont
; change char to "led off", depending on counter
IFSET LED_FLASH_CTR, 5, movlw 0x10
LED_SetDigitCont
call LED_GetCode
movwf LED_TMP
;; scrambling:
;; LED a: PORTA[0]
;; LED b: PORTA[1]
;; LED c: PORTA[2]
;; LED d: PORTA[3]
;; LED e: PORTA[5]
;; LED f: PORTE[0]
;; LED g: PORTE[1]
;; LED dot: PORTE[2]
andlw 0x0f ; PORTA[3..0]
IFSET LED_TMP, 4, iorlw 0x20 ; PORTA[5]
xorlw 0x2f
movwf PORTA
swapf LED_TMP, F
rrf LED_TMP, W
andlw 0x07
xorlw 0x07
movwf PORTE ; PORTE[2..0]
return
I just have exchanged the polarity with the xorlw instructions
Ok …cool
Bit late now for mackwrecks one I’ve changed the leds but I’ll use it for mine anyway he he he ;)
Thanks anyway TK
I need to change the source to suit sending bank change instead of program values ???
Hint hint
Thanks
Ian
BTW I chucked a burn into an 877 and that worked too :
Ian
