First time testing MB6582 without CS
http://www.neutrik.com/fl/en/audio/210_301451/NMJ6HFD2_detail.aspx
… but I don’t really know the exact part number. I’ll get him to confirm.
That is the right one.
Best regards
SmashTV
I still need to order the correct jacks, cause i would like the mixdown. Where can i order these? Cause on the site i don’t find a way to order them.
greetz
Neutrik Part # NYS216
Mouser Part # 568-NYS216
I got mine from Electro Sonic here in Canada. 10 or more for 41.1 cents Canadian each seemed like a steal so I bought 25 along with some other parts. http://www.e-sonic.com
This info should be added to the construction guide I think.
Think that’s the wrong part # for mouser. I looked up the manufacture code. And i’m getting mouser part # 550-20301.
I looked further and i found the following plug on www.reichelt.de :EBS 63P.
Can someone confirm this is a correct jack plug.?
Grtz
Observe difference in the pins - this jack would not fit flat against the PCB. Although if you had no other choice, you could buy these and trim the pins with wire cutters.
That is exactly what I did with exactly that part exactly five minutes ago. Works more or less fine.
Why Mouser has two different Manu codes for Neutrik is anyone’s guess, but the main difference I see between your part and mine is that mine has kinked legs so it snaps in place on the board.  In fact, both are on the same page of Mouser’s catalogue.
But I recommend the NYS216.
