First compilation: Error compiling main.c (no such file or dir)
Hi to all, i do not have yet a midibox (i’m waiting for my ordered Core). In the meanwhile i’,m trying to understand how to program Midibox apps in C.
I have so followed the wiki guide, and installed all the toolchain.
But, when i do make, i get an error (no such file or directory on mios-gpasm).
I have Miosbase and all the tools intalled in the right directories (or, at least, i believe so).
I try to post the error i get, hoping for someone to understand it:
F:\mios>make
rm -rf _output/*
rm -rf _output
rm -rf *.cod *.map *.lst
rm -rf *.hex
mkdir -p _output
sh f:/miosbase/bin/mios-gpasm -c -p p18f452 -I./src -I f:/miosbase/include/asm -
I f:/miosbase/include/share -I f:/miosbase/modules/app_lcd/dummy -DDEBUG_MODE=0
-DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I f:/miosbase/modules/mios_wrapper f
:/miosbase/modules/mios_wrapper/mios_wrapper.asm  -o _output/mios_wrapper.o
  f:/miosbase/modules/app_lcd/dummy/app_lcd.asm -o _output/app_lcd.o
sh f:/miosbase/bin/mios-sdcc -c -mpic16 -p18f452 --fommit-frame-pointer --optimi
ze-goto --optimize-cmp --disable-warning 85 --obanksel=2  -I./src -I f:/miosbase
/include/c -I f:/miosbase/include/share -DDEBUG_MODE=0  main.c -o _output/main.o
f;C:\MSYS\1.0\miosbase\bin\mios-gpasm: f;C:\MSYS\1.0\miosbase\bin\mios-gpasm: No
make: *** [_output/main.o] Error 1
F:\mios>
The line that gets the error (the last one) referrs to the miosbase directory (the miosbase package) inside the MSYS dir… But my miosbase dir is located elsewhere (and setted using the MIOS_PATH and MIOS_BIN_PATH variables).
I also tried to copy the miosbase inside the MSYS dir, but i get the same error (obviously mios-gpasm is in place, and exists..)..
I’ve used an SDCC skeleton from http://www.ucapps.de/mios_c_filter_cc.html (just to give a try, as i would like to build a simple midi processor with my Core)..
Sorry for the silly question, but i’m a midibox newbie, and just want to be prepared on the software side when i will receive my Core…
I also post a DIR of my make directory:
F:\mios>dir
Volume in drive F has no label.
Volume Serial Number is BA4F-AA31
Directory of F:\mios
11/01/2009  14.01    <DIR>          .
11/01/2009  14.01    <DIR>          ..
11/01/2009  13.22    <DIR>          -p
11/01/2009  13.30            5.580 main.c
11/01/2009  11.43              936 Makefile
11/01/2009  13.27                96 path.txt
06/08/2008  01.17              896 README.txt
11/01/2009  14.01    <DIR>          _output
              4 File(s)          7.508 bytes
              4 Dir(s)  2.259.890.176 bytes free
F:\mios>
Thank in advance !!
What’s up with the forward slashes?
You’re right, changed the reverse slashes, and now it compiles correctly. Thanks.
