The values of the capacitors affect the filter cutoff frequency range.
Therefore, it is better to use as closely matching values as possible in a stereo SID pair, so the difference in cutoff frequency between the SIDs is as small as possible when both SIDs have the same cutoff parameter. I can definitely hear the difference between closely matching values and values differing by 10% (eg. when using low-pass on a PWM bass patch). I call this a “phasing effect” (probably incorrectly using the term) which is something you might want and can achieve by setting the left and right SIDs with different cutoff values, but it’s better to have it optional.
Any non-polarized capacitor type will work I think… the differences are more to do with temperature stability and lifespan and other things which I don’t know much about. I’m personally using mylar (polyester film?) capacitors with 1% tolerance, a lucky find on eBay, otherwise I’d be stuck trying to find 1% tolerance capacitors of any kind.
So when i’m reading this, the idea pops in my head of a on-off-on switch with 3 different values for the cutt-off range. Or is this not a good idea? And do both C1 and C2 affect the filter? Or is for instance C1 for filter and C2 for resonance? Please inlighten me…
"both caps should be the same value. normal operation of the filter over the audio range (apprx 30Hz - 12KHz), is accomplished with a value of 6800pF for C1 and C2. Polystyrene capacitors are preferred. In complex polyphonic systems, where many sid chips must track each other, matched capacitors are recommended. The Frequency range of the Filter can be tailored to specific applications by the choice of capacitor values. example, a low cost game may not require full high-frequency response. In this case larger values for C1 and C2 should be chosen to provide more control over the bass frequencies of the filter. The approx maximum Cutoff Frequency of the filter is given by:
FCmax = 8.2 - 5/C
Where C is the capacitor value. the range of the filter extends approx 9 octaves below the maximum cutoff frequency."
Seems like both caps are only for the cutoff frequency bandwith range.
Sound like a good idea. I would be interested in this too
The theory with using high-end plastic caps (well, from what I can gather in the HIFI geek land), is that ceramic caps can be slightly microphonic, or piezoelectric, which can cause distortion. Personally, I’m not sure how much difference it makes in this application, but I use the best caps I can (within reason, no $20 Spragues here ).
So what kind of caps do you use then Jaicen? And what is the exact function of C1 and C2? Do they both regulate the filter cuttoff range? I’ve checked the pin out of the 6581 and pin 1 till 4 are for Cap 1a,1b and Cap 2a,2b so i don’t get any wiser on that.
Like recently i’ve build a tube vcf which also has a switch for 3 different values on the cut off frequency range. Are these caps(c1,c2) more for stabilization?
