fader info
does anyone have the data sheet for the old PANASONIC EVANMKP08B14 faders, looking for the pin info there doesnt seem to be any datasheet on the net. I want to use the old ones on another project so they dont goto waste. Touch isnt important as i have the alps for that.
thanks
Hello
Fader are just pot, 3 pin, you should find the pinout within 30 sec with a ohm meter…
The pin that have variable resistance (across any two other) when moving the fader is the wiper
The two pin that have fixed resistance when moving the fader are 0 and Vref
The pin across the wiper which indicate low resistance when moving the fader down is the 0v
The pin across the wiper which indicate low resistance when moving the fader up is the Vref
Best
Zam
yea i got it Zam, i had to go get new batteries for me meter, if anyone had the data sheet it would have saved time. just put the meter over it and all sorted now thanks
All is good with the faders, i need to open them up, clean and put some fresh teflon grease in there for the slider as it has dried up in them The calibration upper, middle and lower is goood, but will be better once serviced.
