the Midibox Wiki suggests using encoders from voti, though they are detended. I always thought that only non-detended encoders should be used for best performance. What’s the truth?
regards, tom
regards, tom
I read Non-detented somewhere - somehow that should give a higher resolution?
This has nothing to do with performance, but with non-detented encoders you can use the “double resolution” feature (read this thread: http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=parts_q;action=display;num=1048692275;start=4#4) I think that’s what you’ve read.
In general:
NON-detented encoders are godd for ‘smooth’ operation of synth controls (like on the MB-SID or on the MB16E…).
Detented encoders are good for application where you need a clear response for every change of a value (like with the MB-SEQ). Every ‘click’ is a increment/decrement.
So it only depends on your preferences if you use detented or non-dtented encs)
I always use detented encoders… even for soft-synth control.
Just to clarify this “higher resolution” myth:
There is no higher MIDI resolution with non-detented encs!
The higher resolution only means that you get more increments/decrements per angle of rotation. So if xou got 24step encs you will get:
-24 increments/decrements with the detented type
-48 increments/decrements with the non-detented type
So you have to turn the detented enc twice to get the same value as with the non-detented one.
(Or you use the FAST Option in MIOS ;D. That’s what I prefer instead of turning and turning and turn…)
I think the diagram of Thorsten int he mentioned thred makes the encoder modes quite clear.
raphael
and if you want you can still buy from voti; you can make the encoders non detented. I discribed how i did it here:
http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=parts_q;action=display;num=1092049636;start=3#3
cheers,
marcel
thank you very much for your replies.
By ‘performance’ I meant ‘performance of the encoders’, not the core or something else. I had something in mind about ‘resolution’ but it wasn’t quite clear.
I know that different encoders can not alter “MIDI resolution” in any way. (Why should anyone believe that?)
In any case I will order encoders from voti now, the price is unbeatable… ![]()
regards, tom
Hey Tom,
I didn’t want to offend you!
If you hang around for a while in this forum, you will hear some quite funny questions about MIDI and electronics… ;D
So I thougt it would be better to clarify the term ‘resolution’ concerning encoders.
Raphael
Hi Raphael,
sorry, I didn’t want to offend you either and I’m sorry if I gave you the impression of feeling offended.
I know that many strange questions are asked in this forum and in fact I do very much appreciate you giving a detailed answer though you might think it’s a funny question.
This is one of the best characteristics of this forum; people are very friendly here. I’ve seen a lot of places where people try to impress each other by their smattering and where they’re defending their opinions in a rude tone.
bye and regards, tom
