Hello
new to this forum and I know nothing about building electronic gear/midi boxes. Sorry.
But I play guitar, have a producer studio and make a lot of music and sound design.
And I have an issue (could me small…):
i have a Tc 2290 - an old unit (1985) from TC electronic, out of production. It a combined dynamic delay and effect controller, used by folks like The Edge, Robert Fripp and Robben Ford. It is still considered one of the best delay/modulation units. It has 5 inserts for pedals (4 mono, 1 mono/stereo), It can send and receive midi, also got a midi through function. BUT it cannot send/receive CC messages.
It is controlled by Tc 0144 (I have one) a non midi foot controller (sends messages through a standard guitar cable). The TC 0144 can controll everything on The TC2290, including midi program changes.
neither the tc2299 or the tc0144 has an input for expression pedal.
I want to combine this set up with Meris Mercury 7. I want to both change presets and use an expression pedal with the Mercury7. I’m about to buy the Mercury7 but the Meris pedals “only” have a trs input for controlling either exp., tab or midi, unless you buy a dedicated controller.
I want send both pc and cc messages to the pedal, pc messages from the tc2290 and cc messages from an expression pedal. I want this to work on more than one pedal, if I decide to buy more than Meris pedal. (The Polymoon looks and Sound cool).
so I need something like a merge box, that merge pc and cc messages and have input for both midi and an expression pedal and send these massages to the Mercury7.
and, when I probably will buy a Polymoon I would like to be able to also send pc and cc messages to this.
is it possible?
Does a box like that excist?
or can someone build it?
I’ve contacted Meris - they told me to buy Morningstar mc6 ll + Meris midi I/o.
so i then send midi to Both the Tc2290 and to the meris I/o..?
and dump my TC 0144., altough the mc6 Can also receiver midi, so i could send midi from the tc2290..?
I know that midisolutions has a pedal controller (waiting for answer)
i know the disaster Area have stuff in this area (waiting for answer)
i know I try to combine 1985 gear with modern gear.
Maybe you Can help to clear things up.
If you need info about TC2290 and/or TC 0144 you Can find it here: http://www.tc2290.com/
i Can also provide excerpts of manuals
best regards
Søren Bendixen
