Duggle - Gallery Album
Album by Duggle
LCD core connections (small)
Detail (note twist required with this particular display)
simple keyboard split (for upcoming blog article)
Velocity crossfade zones (for upcoming blog article)
Core backlight driver circuit detail
Modded backlight drive circuit
unterminated chain
series terminated (220ohm at source)
Long DOUT chain test setup
100R source series termination on long chain
RTC cct diagram
Hacking GMRSNT.dll
This shows configuration of com port in the Kawai serial to MIDI driver. Use a hex editor to change this string to whatever com port or baud rate you like. Change content:-Do not change the size of the file! Beware that USB com ports may change their COMn: number.
ENC28J60 beware switched Net labels
This ENC28J60 PCB has the net labels for serial in and out swapped. I would have thought the net labels on the PCB connector would match the functions of the pins that are to the chip. I was wrong.
StateViewer output
An example of StateViewer plugin for Eclipse
vTaskList output
An example of DisplayTasks() {uses vTaskList()}
back Of unit (cropped)
Back of SEQV4L modified to have 4 MIDI ports
Detail Of J5B track mods(with text)
Wiring of MIDI Port 3
keyboard shots(cropped)
Newly build Midibox KB. 2x61 keysRoom on the left for pitchbend and modwheel.
Vel curves
Vel curves
generic velocity curves. Input velocity (keyboard speed) is on the horizontal axis, the midi note velocity output is the vertical axis.
NG 64 ledring LCD CS diagram
NG 64 ledring LCD CS diagram0001
NG 64 ledring LCD CS Detail
minicore
8x8 Colour Matrix
Appnote Cct with Examples
ExModwheel
ExPitchbender
smaller
multiLCDsch
Schematic of for interfacing multiple LCDs to MIDIbox NG
NGL upload problem
Keyboard Rig Midi wiring 4
Midi Wiring 5
basic
20130616 214313
basic(small)
20130616 214313(small)
RGB LCMeter idea
