I’m developing a finger drum controller, like Future Man’s kit (dude who plays drums for Bela Fleck), or like a Zendrum… I’ve been experimenting with piezo pickups in different casings, connected to a teensy 3.6, and those seem to be working pretty well in terms of registering the relative strength/velocity of different hits. My take was that MIOS wasn’t really equipped to handle reading piezos right now, and that some amount of work would be required to add that capability, but also that designing a Teensy-based drum sensor wouldn’t be too much work… And that my design was essentially for a standalone drum controller anyhow, which could be connected to a Midibox via MIDI anyhow, so figured I’d just do it standalone.
Would be cool if MIOS got the ability to read piezos, but from my experiments the reading algorythms are pretty dependent on the physical configuration of the sensors (like, when you put the piezos in different casings, they read differently, and the algorythm has to compensate to avoid triggering from vibrations when you hit neighbouring sensors - would be possible to make a one-size fits all solution, but there would have to be some built-in calibration functionality).
I might be into helping with an effort to incorporate piezo sensing into MIOS if that was a project that would be of interest to people though - would open up a bunch of neat options for MIOS based projects… But it may be too much purpose-specific code to throw into a codebase where most people wouldn’t be using piezos… And a standalone Teensy based system makes some other neat options possible, like using capacitive touch to sense drumskin damping, motion sensor effects modifying drum sounds, etc.
For casings, I’ve been experimenting with little foam-packed plastic and metal containers, with piezos mounted on the lids, and also with sandwiching piezos between hard rubber adhesive pads (sandwiches made of 3M adhesive hard rubber feet a few mm thick, clear rounded epoxy plastic stickers, and some various other materials). Both work well. Also playing with ways to mount lots of sensors on one instrument without having hits on one sensor affect others - vibration isolation by mounting all the sensors on rubber/foam pads, etc. Anyway, from what I’ve found so far, because of the nature of drum sensors and all the associated acoustics/vibrations, there are a lot of implementation-specific things that a one-size-fits-all algorythm would have to take into account - considerations that don’t exist when you’re reading tact switches, encoders and pots… A MIOS implementation would have to be pretty flexible in order to be useful.
I’ve got a launchpad pro, which is velocity sensitive (force sensing resistors, I think), and I find it doesn’t really give as good a “feel” for finger drumming as the piezo sensors do… That might be a calibration issue, I guess, but I think the piezos give a more accurate read of hits.
