This is why I keep my external bays on the floor
Im sorry I was late in seeing this, but I have had MANY successes in recovoring drives from the dreaded click start.. here is the general procedure:
1: buy a replacement drive..
you will only ‘get it back once’ so you need somewhere to immediately back it up too.
2: listen to the boot sound.
the often described ‘click state’ is a common ‘droped drive’ failure. Essentially what is happening is one or more of the drive heads has come out of alignment and will no longer park in the head lock mechanism (it is actually clacking into the park slot, rather than slide inside). The drive will not allow reads (and thus boot) if the head is unparked during power up (it wont even spin up). So, it attempts several times to park the head before spinning up the platters (that way, if the platter gets scratched it is only a sector or two and not the whole platter in the spiral circle of death).
3: Prepare your work system.
If this was your boot drive, you need to build up a completely working (booting) system, along with the required data space to back up what you want.
4: Plan ahead.
Remember your drive structure, and what you want to save first.. prioritize what you will save in case you cant get it all.. For instance, go after the “My documents” folder first.. followed by photos, then large file size data like MP3s and video.
5: open the dead drive cover.
Find a CLEAN area to work in. If possible, get some latex gloves. They are not mandatory, but a little extra precaution doesnt hurt. NEVER touch the platter!!!
The idea that you need a vacume state or a clean room is rediculous.. those are selling points of the data recovery ‘specialists.’ There really isnt anything special about it.
Platter swapping is an easy job too but beyond the scope of the home user simply because A: you need a large stock of exact model drives to swap the platter into, and B: you need special screwdrivers and an alignment tool.
You dont always need fancy screw drivers either, but a good set of precision drivers comes in handy. Dont Pry on the cover, you need it. Feel under labels for screws you may have missed.
6: general Inspection
95 percent of the time you will see the head sitting out over the platter.. this confirms your problem. Carefully inspect the the top platter. In fact, its the only one you CAN inspect. check for scratches or obvious damage. Also, when the cover comes off, you might find a small piece fall out.. this is part of the head lock mechanism. Watch for it.. and take the time to figure out how it goes back on. It just sort of sits there, so it likely wont stay in place as you play with the drive, but it needs to be in place when the cover goes back on.
7: move the head
The opposite end of the head sits away from the platter. It is usually isolated from the rest of the drive, as the strong magnets are there. We are looking at the end of the arm opposite of the head..
from this end, carefully and slowly rock the head arm away from the platter, till it is on the edge of the platter. NEVER move the arm on the using the side of the pivot close to the platter.. the big chunky massive end where the magnets are is not going to bend under your fat sausage fingers
Now, with a bright light shining gown, watch as many heads as you can as you rock the heads off the platter.
One or more may ‘fall off’ or ‘snap off’ the platter. These are your missaligned heads.
If you are unlucky, you will have one or more. Unfortunately, there isnt much you can do to fix the problem. The precision needed to realign is impossible from home. Any data on the associated surface will be suspect or not available at all.
If you are lucky though (and this is often the case) the heads fly just fine on the platter and never touch. If this is the case, you will be able to recover nearly all your data.
8: park it
The head lock is a plastic piece that holds all of the heads in little slots. Often this is the only real failure of the drive.. some part is either broken or misalligned. Fortunately, all the drive knows about the head position is from feedback on the magnet, and one small mechism that latches.
So, you can take one of two courses of action: Destructive or nondestructive. TRY nondestructive first.
Non destructive:
Simply place the head back into the lock cradle and replace the mechanical latch so that the head is ‘locked.’ you may need to help one or more heads into the cradle if it is misaligned. That is afterall the reason the drive failed. It couldnt push the head back into place.
Manually test the release to make sure they heads fall out smooth and slip over the platter without crashing. again, you cant help it much if it scrapes a platter.
Assuming it all looks good, re-park the head, replace any part of the mechanism that latches the head down (often this is a piece that falls out when the cover is removed but usually easy to figure out where it goes), and put the cover back on.
Destructive:
Remove the head park slots so that the head will float in open air where it should be parked. The feedback from the magnet coils ‘should’ assume the drive is parked but I cant verify this is true on every drive. If you are going to do it this way, you need to place the head, put the cover back, and connect and run the drive WITHOUT MOVING IT… thats sort of a tall order. Have your system in place, with cables pluged in. Leave the drive on the desk face up.
9: back it up
Ok, so you have the drive back together. You now have one shot (not exactly that bad, but we will get to that
Plug it into a working system.
A note: your system needs to be a fast booting machine, Not one that runs 300 extensions and virus scanners and whatever else. You are going to run the drive as a slave device. YOU MUST NOT ALLOW IT TO HAVE TIME TO GO INTO SLEEP MODE. Keep the drive active. The faster you can get into ‘my computer’ and backing up data, the better.
so you boot up… now is the day of recconing.. if it shows up in my computer you are golden. Get in there and start copying as much as you can.
Remember, if the drive is left inactive, it will attempt to sleep..sleep mode means it wants to park.. as soon as it realizes It cant park, it will call it dead, and you have to start from the beginning.
If you get it working and see the drive, test a file.. read a text file or something from my documents.. or copy one file..
If this works, then you can repeat the whole procedure several times if need be to get all of the data you need. Just dont cause any NEW damage.
Example: one platter has a scratch.. a few files will not read.. half way through backing up data.. so it hangs and crashes. Well, just perform the procedure again. Now, forget about those files, they are gone. Move on to the next chunk.
Success stories:
I performed this on a droped laptop size drive from my Creative mp3 player. The player could find any song and play it, but about half way through the song the drive went to sleep and it died.. I did the procedure again and this time backed up the entire drive by connecting the player to my desktop machine via usb and reading all of my songs out.
I performed this on a friends laptop drive. In this case, I actually reinstalled the bootable drive into the laptop, and booted from the supposedly dead drive. I then immediately backed up all the data to an external full size drive. On reboot the drive continued to work fine, until the machine was left for a few minutes doing nothing (the drive was not completely power cycled, so it never made an attempt to park, thus it didnt ‘fail’ until it was unattended and attempted to sleep the drive). We installed a new laptop drive then copied the data back from the external bay.
I did this twice on dead desktop drives but in both cases the platters were damaged and some files were corrupt, as well as some filenames being really strange.. 75-85 percent data recovery. But, these drives had also suffered heat damage.
Note in all cases, the damaged drives could all perform normally untill the drive went to sleep or was completely power cycled. In almost all cases, the drive will survive multiple ‘operations.’
So, if you get part way through data recovery, you can try to perform the job again and get the next chunk of data.
Hope this helps.
and hey, in your mind, the data is gone.. so.. why not try it?
