display and SID ( thorsten )
So it seems that I also do not really need the LCD on the core for the SID either.
Is this right
If so then what do i do with these left over connections from the PIC.
I don’t really need the buttons either do I ?
TIA
Ian
Further to my questions about the SID connections :
Ok junction 2 goes to 7
But… on the SID there is another connection called MU
which comes from the 595 pin 14.
Could you tell me where this connects on the core ?
Thanks
Ian
Hi Ian,
currently, neither the LCD, nor buttons or pots are supported by the SID firmware. Of course, you see some messages on the display and the buttons seem to trigger some functions, but these are for my private use (debugging functions) and therefore not documented…
In the last posting there was a mistake: the correct connection from core to SID goes from Core:J10 to SID:J2 - both are 8-pin headers (not all pins are used), so you cannot make anything wrong. :slight_smile:
If you don’t use the original MBHP modules, don’t forget to add pull-ups on Pin RA4 and RD1, otherwise the firmware could crash.
P.S.: J7 delivers the 1MHz clock if no oscillator is available - see http://www.ucapps.de/mbhp_sid.html
Thanks TK
I picked up the J10 thing but was going to pose the question anyway…good shot.
Thanks again
Ian
Pull ups thru 10k  ?
Ian
OOOOH
It makes noise !!!
TK  I am using logic 4.8 and the enviro for the SID won’t
load.
Could you save a version in something below V 5 and bang it on the site
Yipeee
Ian
Problem solved - have taken the Logic Environment and saved it as a v4.8 LSO - just so PC Jimmy can have some fun … even though he’s out of date with Logic!  ;D
