DIN sync with LPC17
Is anyone else using DIN Sync with an LPC17?
No, what’s your set up? Have you level-shifted the 3.3 V signal?
So far I’ve just put a din out on j28 and didn’t measure a voltage at all when there should be 3.3v on run I believe. Then there would be something to level shift anyway.
Please explain your set up. Are you using the Wilba control surface? Do you have the SEQ running correctly? Have you edited the hardware config file?
This is the schematic which shows the 74HCT541 based level shifter at J28:
http://www.ucapps.de/mbhp/mbhp_core_lpc17_output_buffers.pdf
The usage of this chip is not only recommended for voltage adaption, but also to protect the LPC17 IO pins against short circuits.
