din_key_offset not working
Hey,
I have a problem with a 76 key organ keybed. This is my configuration:
KEYBOARD n=1   rows=12  dout_sr1=1  dout_sr2=2  din_sr1=1  din_sr2=2 \
               din_inverted=0  break_inverted=0  din_key_offset=10 \
               make_debounced=0 \
               scan_velocity=1  scan_optimized=1  note_offset=9 \
               delay_fastest=25  delay_fastest_black_keys=15 delay_slowest=1000
The right half is completely out of tune and I’m not able to adjust the starting key with din_key_offset. It doesn’t matter which number I choose for this parameter. The notes will stay the same…
Any help on this?
Thanks,
Chris
Are you using the keyboard.c driver with FANTOM_XR_VARIANT switch set?
The din_key_offset parameter isn’t used with this switch.
Hey,
I’m afraid no. I used the official KB and NG release from ucapps.
It’s a strange behavior. Any other ideas? I can make some photos of it tomorrow.
Thanks,
Chris
I won’t have the possibility to help you on this issue the next days…
