Well, you all amaze me.
I started with such high hopes more than a few years ago on a MBHP 64 project, then put it away as I got busy with other things. I feel technically inept. I thought that I should complete the box for better or worse, so I determined to make the box work (this might be my mistake).
I am using a Smash TV board, pic, and components that I purchased 3.5 years ago.
The pic is labeled MIOS_BOOTSTRAP_v1_1B
All 0’s underneath.
I have attempted to use MIOS Studio to upload: update_without_installed_mios.hex
When I start the upload with:
Device id 0
“Wait for upload request before starting upload” checked
and Smart mode
I receive the following message:
Starting upload of update_without_installed_mios.hex
Hex file contains code in MIOS range, forcing reboot!
Received Upload Request
Sending block 00000000-000000FF
Error: Received unexpected Upload Request
(Sending block and Error repeated until abort)
I tried the following from the midi troubleshooting guide:
TEST IN1: Ok
TEST IN2: Ok
TEST IN3: LED stays lit (even with no message coming in?)
TEST IN5: Ok
TEST IN6: LED stays lit regardless of switch position
Thank you for any help in advance. I should have just stuck to playing guitar.
John Gregory :
