DataWheel Midibox64
Hello, sorry for my English is not only a google translation of my french
Well, I’m on the end of a MIDIbox64 for Hammond clone, but I do not understand how (despite the explanations I could Rescueing) replace the navigation buttons by datawheel in the program. I need help.
Thank you in advance to all
It requires some changes in setup_midibox64.asm and mios_tables.inc (as described in the files), but I must admit, that the change isn’t straightforward… in addition you’ve to install the MIOS toolchain to recompile the application.
Anyhow, I could change the setup for you and give you a .hex file… Next week after my holidays.
it will be super nice of you, thank you. And I await your return from holiday with impatience.
Finally a preconfigured firmware where the left/right button can be replaced by an encoder:
http://www.ucapps.de/mios/midibox64_v2_4f_with_datawheel.zip
DIN Assignments:
EXIT button at D7
SNAPSHOT button at D6
Encoder at D4/D5
wow i could have used that a long time ago. just figuring out the encoder thing now and i built my box more than 6 years ago.  ;)
I’m going to have to modify it a bit and add that one encoder for up and down scene selection in ableton.
