D3 connection for CAN interface
I’m ready to start connecting my LCD (2x40) to CORE for my first project and have been studying the mbhp_lcd_4bit.pdf and the docuwiki and searching around the forum to make sure I’ve got everything in my head before starting.
The one thing I would like help on is connecting the 1k resistor from D3 to +5v. How are you guys doing this? Are you soldering one side of the resistor to D3, then running a jumper wire to anywhere on the CORE that has +5V from the other end of the resistor? I was thinking of jumping it over to the + side of C5, since I left that capacitor out of my CORE. Is there a better way of doing this?
I understand what to do with D0, D1 and D2, but D3 has me stumped.
The Vd (+5v) pin is right nearby.. perhaps that might be a good location.
Yeah, that makes sense. Thanks for the suggestion! I was focusing on the Core connections other than the LCD and didn’t take that into account. Sometimes you can’t see the trees because of the forest…
It just occurred to me that if you aren’t making use of the CAN interface, I don’t think you have to worry about the pull up resistor.  You could always give it a test without it.
Just found this on ucapps.de
It is possible to control up to 3 additional synths from the same frontpanel. The first core, which also manages the control surface, will act as a “master”, and the remaining cores are handled as “slaves”. Communication is realized over a fast CAN interface, this approach is called MBNet.
So, I don’t think I’ll be using CAN. I’ll leave that connection out and test it.
I added CAN Interface to the WIKI - MIDIbox acronym page.
If you search more, you’ll also find the doco that says you should install the parts even if you don’t use CAN.
As striddie said, do install the parts no matter if you use the CAN interface or not. Make sure to disconnect D0-D3 or it might fry your LCD. Just get a good look at the board layout and trace the D3 pin - you can hook up the resistor anywhere on that track. Just pick a location that’s close to any +5V pin and you’re good to go.
