on the LPC core, i should get a DAC-Output on Pin: (at least the shematic says that)
J5A A3
on App - init i put:
aout\_config\_t config; config = AOUT\_ConfigGet(); config.if\_type = AOUT\_IF\_INTDAC; config.if\_option = 0; config.num\_channels = 1; // INTDAC: only 2 channels supported, 8 channels pre-configured for your own comfort config.chn\_inverted = 0; AOUT\_ConfigSet(config); AOUT\_IF\_Init(0);
(there is only one Internal Dac on LPC?)
and in the programm itself (app-tic)
i update the CV voltage like this:
AOUT\_PinSet(0, CV\_OUT); AOUT\_Update();
while CV_OUT is a value from 0-65535… (?)
(or what Bitrate has the Internal DAC?)
or is there also a Pin-Crossing like on the STM-Core (SD-Card)?
for the moment it doesnt work… maybe i miss something - but with the things i wrote above - i get a Aout-NG working in the past…
best-mike.
