Custom Linker Script Hint
Hey boxers!
Quick tip for you, regarding the new unified mios platform, and custom linker scripts…
You can specify your own linker script, like many things, in the makefile. Chances are, you’ll put the linker script in the same directory as the main.c, right… So you copy your makefile from ‘\trunk\etc\lkr’, into your app’s root dir, and you make your mods… Then you edit the makefile.
The original:
# define the processor, linker file and project name
PROCESSOR = 18f452
LKR_FILE = $(MIOS_PATH)/etc/lkr/p$(PROCESSOR).lkr
PROJECT   = project
The mod:
PROCESSOR = 18f452
# Custom linker
LKR_FILE = ./$(PROCESSOR).lkr
PROJECT   = project
Now, you’re probably thinking like “Duh” right about now. But there’s one important thing to note there, and it’s pretty subtle.
This:
LKR_FILE = $(PROCESSOR).lkr
Will compile. No worries. But it won’t work with the dist script. You need this:
the dot-slash is required. That’s all, enjoy!
