Arnak
March 24, 2008, 11:20pm
1
Could someone advise me on the voltage range to be expected unde load on the core module please?
I have checked some of the core module test points and get 3.41v under operating conditions.
I do have 5v at the DIN module connections.
Is this within an acceptable range?
Perhaps I should mention I am using a 1500ma supply at 9v.
Arnak
Sorry Arnak can you be more descriptive? 3.41V would be too low at most points (the correct voltages are listed on ucapps.de ) but could be normal at some of them.
Arnak
March 26, 2008, 10:14am
3
Hi Stryd_one,
Thanks for that, I’ll check out ucapps again, it’s probably a bad joint on the core board.
Arnak
bill
March 26, 2008, 11:54am
4
Wow!
It’s off topic but :
Take care and dont short circuit anything, 1500mA is pretty much current
(200mA should be far enough for most mb purpose, even with a backlighted lcd screen)
Arnak
March 27, 2008, 10:50pm
5
Hi Bill,
Yes, good point,I’ll be careful.
The large supply is for the further code modules (3) and DIN and DOUT boards that will need to be driven, about 18 in all!!
Arnak
