i added 4 PCBs yesterday
what is the price with 500 boards on the order :laugh:
I havenât asked to my manufacturer but unfortunately after 100 units the price drop but not as much as before 100s, and more you order more the drop is decreasing.
Anyway I think that 9ââÂŹ is a very good price for that sized PCB! We can hope a slightly drop with the reach of 150s but it should be not so important.
Regards.
To be more precise:
150 units: 8,50ââÂŹ.
200 units: 8,00ââÂŹ.
Regards.
Bad news: Mouser do not stock enough SIL resistor networks.
Mouser estimate to receive the new stocks for the December 5th 2012.
I propose to modify the time-frame accordingly:
Bulk order start: October 29th 2012.
End of the list: November 18th 2012.
I PM (or email) member with the total amount to pay: November 18th - 20th 2012.
Payments will be accepted until November 25th 2012.
I order the PCBs and the Mouser order: November 26th 2012.
PCBs order arrive near the December 5th 2012.
Mouser order arrive near the December 12th 2012.
I ship the PCBs and Mouser components to each member: December 13th - 15th 2012.
This time frame may be subject to change due to unforeseeable events.
Iâm waiting your feedback about this new time-frame to update the Wikipage.
Regards,
Jerome.
Why not leave the bulk order open for one more week, so that PCBs and Mouser items will both arrive close to December 12? Maybe some more people are willing to join ![]()
âŚExact.
New time-frame:
- Bulk order start: October 29th 2012.
- End of the list: November 23th 2012.
- I PM (or email) member with the total amount to pay: November 24th - 26th 2012.
- Payments will be accepted until November 30th.
- I order the PCBs and the Mouser order: December 1st 2012.
- PCBs and Mouser order arrive near the December 12th 2012.
- I ship the PCBs and Mouser components to each member: December 13th - 15th 2012.
I will update the Wikipage if there is no other feedback in the afternoon.
[Edit: Wikipage updated.]
Regards,
Jerome.
I think it is OK but how do you get the stock avalaibility date?
Do you phoned them?
Often the date on the site is not sure at all.
Regards
Antonio
Do you phoned them?
It is the date indicated in their site.
Thank you for the information: I sent to Mouser an email to confirm this shipping date and wait their answer.
Regards.
âŚMouser just confirmed the date of the December 5th 2012.
Regards.
Makes sense to me to extend the time frame.
I slightly modified the design of the board.
The revision is now 2.4 and the improvements are:
Cap C5 positioning near âINâ DIL header.
Silkscreen improvements.
Iâve named the board âMB-2X8LRE-CSâ trying to respect more or less the Midibox naming.
âMBâ stand for Midibox.
â2X8â because 2 rows of 8 columns (maybe one day there will have 2X4 or 1X8 board).
âLREâ stand for LedRings Encoders.
âCSâ stand for Control Surface.
I would like to have your feedback about it and waiting your suggestions.
Regards.
Sounds reasonable to me, although I would probably put it MB-LRE8x2CS, as the LRE is the more important info compared to the 8x2 âform factorâ. Also, I think we had the BLM 16x4, for which the number of columns were mentioned before the number of rows.
MB-LRE8x2CS adopted (if anybody see any objection).
Regards.
Updated price of the DIL RN in the Wiki because we reach 200 units: 0,26 ââÂŹ.
Regards.
I just took a look the the hi-res PDF layout - have you performed a design rules check (DRC) and resolved all errors? It seems that every other LED shows a marker that looks as if DRC had detected something? Also, I think that some of the tolerances might be a little on the risky side, e.g. with respect to distance between some tracks and ground plane. Your manufacturer might support those tolerances, but are you on a 0% failure rate guarantee? If not it might make sense to increase tolerances somewhat.
Best, ilmenator
Best, ilmenator
Thank you ilmenator for having checked the layout.
The layout pass the Eagle DRC default rules (8mil minimum clearance, 10mil minimum wire width, âŚ). I do not use extra âriskyâ tolerance that some manufacturers can handle.
The yellow x-crosses you can see are âzero length airwiresâ, they appear when the intersection of 2 wires of the same signal are not exactly on the same grid (in our case, they are produced near pads but the connection is made effectively inside the pad).
http://discourse.midibox.org/t/topic/16649
Regards.
This is a better layout with a scale factor of 1,7.
Regards.
[Layout_scale_factor_x1.7.pdf](< base_url >/applications/core/interface/file/attachment.php?id=10182)
Sorry, I did not remember Timâs comment. Obviously, everything is under control, thatâs very good
Youâre welcome. Two pairs of eyes are better than one.
Regards.
added order for nð4 pcb - nð32 10k SIL RN - nð8 220 Ohm DIL RN
good work.
