Thanks for the link and the idea… the transparent acrylic will be a good alternative to very costly aluminum-based panels with hundreds of LED holes - which would also be terrible to mount in conjunction with flat-top LEDs - whoever has a MB6582 with them knows the pain
Yay for more Shruthi/MIDIbox cross-pollination! Guys, what if one was to draw a simple panel for one board? This could be cloned times x for larger panels and maybe we could ask the kick-ass friendly mr fcd72 (Herr Daniels) himself if he’s interested? He always make beautiful Shruthi, Anushri and Ambika plus Shruth XT cases for us builders :sorcerer:
I’d certainly be interested in such panels if we can twist Frank’s arm. Heck, ordering one or two of these from him would probably twist MY arm into adding an Anushri case to the order!
I need to expand my rack to 8U, but taking the BCR off the top should save that much space.I was digging in my junkbox last night for some resistors, and came across an unfinished project that would receive and decode a remote control into MIDI volume messages.
This looks like a good time to finish that project.
I really like the translucent panel idea, that should reduce the panel holes to 16 + 4 for mounting.
I just can’t decide what color LED’s and plexi.. something to think about.
For my future panel I’m thinking black anodized alu, with big holes around the encoders and matching “smoke” acrylic inserts to view the LEDs through (a bit similar to an LCD window but now with a hole in the center to poke the encoder shaft through).
It will be not exactly hole but “D hole”, isn’t it?.
Sure it will be a hole, and bigger than the shaft too, but small enough so the knob skirt will cover it (see the MB6582 frontpanel; shafts poke through but holes are invisible with knobs on shafts).
The acrylic will be glued to the alu from the bottom, and will have a recess for it to be flush with the frontpanel, like an LCD window.
We can imagine a lot of nice things to do but the problem with metal panel is the price.
Yes you are right; the cheapest option is probably to just have a second job and buy all your toys with the extra money. Building them yourself is a big part of the fun though, and fun is allowed to cost money IMHO :laugh:
…I spoke about the metal hole not the acrylic hole for the shaft.
Ah now I understand what you mean.
It doesn’t really matter what shape the acrylic is as long as it matches the metal and show all the LEDs. You could even make a U shaped insert if you want. I thought round inserts are probably easier to make (and maybe cheaper).
How about home-cast clear knobs that are big enough to show the LED ring under them?Might look cool, though a bit big..?
