CC naming per synth
Hi all,
I don’t know if I’m right to post in a separate topic but I think it will be easier for other people to find the thread if needed.
I was wondering if it is possible to name the CC on the MIDIBOX SEQ V4+?
As of now, they are named after the general midi specification but I would like to be able to specify a name for each number in the preset of a track. For example, my Blofeld receives tons of CC but it’s always a pain to lookup the CC in the midi specification of the synth. The same goes for my LXR Drum Synth.
Thanks for any response!
Laurent
I don’t think a custom naming is possible and every synth will likely use different names. But how about editing the respective label file?
https://github.com/midibox/mios32/blob/master/apps/sequencers/midibox_seq_v4/core/seq_cc_labels.c
Then recompile the app with the change implemented.
, this will work for one synth only I guess, correct? How would you handle multiple with different CC assignments?
I’m coming from squarp pyramid where they have a great feature where you can create a config file for each synth you own that includes all the midi setting and labels for all CCs. Awesome feature.
 Sorry, I forgot to answer… Yes, that would be a solution but only for one synth from my understanding. It would create more confusion since I’m using several synths.
 That’s exactly what I would like. Currently, I have a preset and a track category for each synth/drum machine, it would be awesome to label the CC according to them. For now, I just lookup the CCs in the manual :)
On 8/28/2020 at 9:37 AM, latigid on said:
Seems like I will have to print a couple CC lists as well :wink:
