its time for a
Midi - control - Change Looper
it records the incoming ccs (from a connected Synth) and sends it looped out again…
it needs also note in and midiclock in order to merge it with the cc-automation and send it back to the synth.
this device makes sense for synths like the clavia nord rack III where we have ledrings as UI.
Features:
4 Midi Channels
128 CCs per Midichannel
4 Pitchbend tracks
256 or 512 Steps at 32th Resoultuion, depends on Ram
Sequencer Tact System standart is 4/4 other systems like 3/4 are set with a CC on the system channel (like programchange)
4 Ledbars to indidacte loop position, and loop length
4x Combined Rec/MUTE Buttons (+shift = Rec)
Copy, Paste, Clear Select, Clear all
Store Load Button
Programchange via Midi, progams saved on SD-Card
2xMidi in, 2xMidi out
SMD LEDs, and good Tactial Buttons.
Easy Case Design a Plexi-Glas Plate with exact one hole (for loop length encoder) + Rest Wood.
a fabricated UI-PCB with J8/j9 connection to plug in a minicore sandwitch.
Small PCB with 10x10cm max to reduce costs to minimum
-a bulk order some prototypes if interest… have to order anyway about 5 pcbs at minimum…
pretty much of the code i have already done by other applications(MSQ-CC-BCR, MSQ-CC-LRE, Filterbox…), i just have to adapt the code and strip down a bit, to get ram free for the 512 steps.
