Finally I have got my JDM working under XP and I have programmed several PIC. So I decided to try them in action, finished my core module, tested voltages, put in a PIC programmed with BootLoader, soldered midi cable, as in http://www.ucapps.de/mbhp/mbhp_midi_gameport.gif and hooked it up to my Live!. Configured MIDI-OX as in BootLoader page. Turned my core on got that nice string after that I tried to SysEx it but I only get that request string. Here is the log:
TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT
0001D83D 9 XXX F0 Buffer: 8 Bytes System Exclusive
SYSX: F0 00 00 7E 40 00 01 F7
0001DFA4 9 XXX F0 Buffer: 8 Bytes System Exclusive
0001E70A 9 XXX F0 Buffer: 8 Bytes System Exclusive
0001EE70 9 XXX F0 Buffer: 8 Bytes System Exclusive
0001F5D6 9 XXX F0 Buffer: 8 Bytes System Exclusive
0001FD3C 9 XXX F0 Buffer: 8 Bytes System Exclusive
000204A2 9 XXX F0 Buffer: 8 Bytes System Exclusive
0066FF4B 9 -- FF -- -- -- --- System Reset
After first string I started sending mios_v1_3.syx, but as you can see it simply don’t get that SysEx. I tried to SysEx it witk onboard sound car, but get the same - nothing. What is wrong? I’m confused:-/, I checked all configurations, reprogrammed PIC without any use.
