i noticed on tk’s sequencer layout that most buttons have an associated led with it, but some do not. is it possible (without difficult modification) for all buttons to light up? at least while it’s being pressed.
I personally don`t see the point of such thing. Also, if the button lights while you press it, you need superbright LED so you can see it light under your finger. If you want to illuminate all the buttons, so you can see it in dark, just power the LEDs all the time. Simple as that. ![]()
there is no point, other than keeping it all uniform. i was going to try to make illuminated caps using acrylic rods. although i think i’ll use your suggestion, thanks :).
