button and LED code help
I’m bulding a MB64, and have a problem I need help with
I need the buttons and leds to work so that only the last pressed button’s LED light up
http://discourse.midibox.org/t/topic/13888
this works sort of, but it affects all types of button press, not only “onOnly” like I would like it to
also I would like it to only affect the buttons within the same shift register
I use 2 SR, the first have 8 buttons with it’s LEDs, and all 8 have an “onOnly” message
I would like these to only light the last pressed
in the second SR I have 3 buttons with “Toggle” message that I would like to light LED when pressed and turn off LED when pressed again
and I have 4 buttons with “onOnly” message that I would like the LEDs to light up only the last pressed of these 4
Is it possible to have the code from the post I linked to to only work for “onOnly” buttons and only within the same SR
I would really appreciate some help with this, my coding “skills” are limited to editing :frowning:
here is a short video of how the buttons and LEDs work now
sorry, I can’t embed
TK, please can you help me out
I have built the hardware and ordered the frontplate :frowning:
here is the code I have changed
;; (button value stored in TMP1)
MB64_BUTTON_OnOnly
        ;; when on: send button value defined in dump
        ;; when off: send nothing
        BRA_IFSET TMP1, 0, ACCESS, MB64_BUTTON_NotifyChangeEnd
        ;; turn off SR1 8 LEDs
    SET_BSR MB64_BUTTON_VALUES_SR0+0
    setf MB64_BUTTON_VALUES_SR0+0
    SET_BSR MB64_BUTTON_VALUES_SR0+1
    setf MB64_BUTTON_VALUES_SR0+1
        ;; save status of button
        rcall MB64_BUTTON_Hlp_SaveStat
        rgoto MB64_BUTTON_Send
thanks in advance
MB64_BUTTON_OnOnly
That’s slightly unreadable… could you reformat?
sorry about that
was trying to embed the youtube video, and it all went pearshaped
Uuuh, I realize that you are coding in Assembler… that is actually my weak side, so I cannot help you here. I guess we need the Assembler gurus to the rescue?
