Just find normal DC adapter and connect the wires directly to the trafo secondary. Just make sure the adapter is hold by screws and it is not glued togerher.
I bought a bunch od old Alcatel mobile 500mA 12V adapters on a flea market very cheap. They are perfect for the x0x.
EDIT:
This is how my second x0xb0x looks like. It has only white diffused LEDs.
No, it is not Lexan. It is Rowmark (french company) Texture. It is material based on acrylic for outdor usage with special coatings to protect it from UV and other weather conditions. It is extremely scratch proof. I think Lexan overlays are printed, my panel is laser engraved.
please, say what? … ???
Vlad, why you think there are something risky about doing it? There are only 2 wires going out of the transformer. As you dont wanna use any electronic just solder the wires before rectifycation diodes or remove the PCB completely as you dont need it. Thet is what I did. I`d let my mother do it with no worry.
The problem is that PSUs i have here are way different, and i don’t understand that much in them. those are much smaller, weighting about 50-100g, like those from cellphones, laptops, scanners printers and zip drives.
Just desolder the PCB and youll left with only 2 wires. Dont use the adapters that has multiple voltages. Find single voltage adapter and you`ll have no problems find 2 wires.
you don’t need that stuff ! Sasha is right, the best is to get a very basic 9V DC supply, already prepared to plug in the wall, opening it, removing the diodes and the capacitor used to transform the AC in DC, and directly connecting the wire to the power jack for the x0xb0x.
