Btn/LED matrix vs direct configurations
The Veroboard is really good quality. Their most durable is the epoxy board. It is much more durable than the paper or phenolic stuff. You can buy it direct :
https://veroboard.com/product-category/the-veroboard-products/view-by-material/epoxy-fiber/
It comes up on Amazon and ebay too. That is where I normally buy it but I do not see a good listing right now.
If you have ever worked with fiber glass before be sure to protect yourself when cutting it. I wear disposable gloves mask and safety glasses. Use a rotary tool with a fiber cutoff disk to cut it. It cuts a lot faster if you cut down a row with the holes in it and they make a nice guide. Also try not to cut it to fast so it does not heat up and smoke. Making a shallow first pass and going back over it a few times keeps it from smoking. It does take some time making the cuts to lay out the circuit but I find it is faster than cutting and stripping so many extra wires. It may or may not be faster than etching a board it depends on how many holes you have to drill and how much time you have to spend laying it out in the cad program. Another design tip if you are using encoders you can run you ground bus below the encoders on a strip and jump over to it with a resistor trimming.
On 22.3.2017 at 10:56 PM, latigid on said:
Try dimmed and see how it works for you.
I got a dimmed LED working, but had to use a range map (eg 0 2) to get a fixed dimmed value. Is there a better way?
Does this method saves power vs resistor solution? I’d assume yes if it’s done via PWM. But i have really no idea.
Thank you.
5"x10" Epoxy Fiber Strip Board Copper USD $13.80 -> 7pcs = $96.60
11.5"x19.5" Epoxy Fiber Strip Board Copper USD $63.40 -> 2pcs =  $126.80
The question is whether strip boards would really help with many mixed parts (leds, btn, pots).
A custom pcb at dirtypcb with 80x25cm cost $250 for 10 pieces. If i could find a manufacturer that offers single pieces, maybe it would make sense to do a custom pcb.
I haven’t tried this with direct DOUT pins. I know for the WS2812-type LEDs “dimmed=1” will allow a CC to control the dimming level as defined in the LED event.
With a resistor, you’re burning current*voltage as heat, so yes, switching the LED via PWM should be more efficient. Measure it yourself: set the multimeter to mA and connect it in series after the resistor. You’ll need a higher value resistor to match the given dimmed value.
Something else to keep in mind is you don’t want a panel full of flashlights. The more LEDs on your panel, the lower brightness they should be (depending on how they’re spread apart).
Check also if your parts have a standard 0.1"/2.54mm pin spacing.
If you’re inexperienced with PCB design, it will probably take the same amount of time (+mistakes) as going the wiring method. That said, it’s a good chance to practice. Consider splitting the panel into subsections, that brings the down cost and shipping is easier. If others find the layouts useful you can sell the extras you don’t need.
You can spend a lot of time routing traces in a cad program. If you etch your own PCB you also need to consider drill time. Limited drilling can be an advantage of strip or pad per hole board in a proto phase or a one off. You have a lot more freedom in part placement when making a board in cad. If you are planning more that one it is definitely worth cad time. +1 to also having more than one board, that will make your life a lot easier when you start to trouble shoot it in addition to the lower cost.
The manual states: “LEDs can now be dimmed with 16 brightness levels over the value range.”. There aren’t any additional parameters mentioned.
Like that it doesn’t make too much sense for simple button/LED (on/off) combos where you want to set a fixed level. The map “trick” does it otherwise.
I tried to measure the current with my cheap multimeter, but failed. It always displayed zero. The fuse in the MM seemed ok but fell apart after removal. So i’ll have get a new fuse and try again. But since it’s PWM is it actually measurable that way?
Regarding flashlights, that why i’m doing all the testing. Maybe i should go with 10mA ones if 2mA is too dark and 20mA too bright.
A single PCB of that dimension would be too risky for a beginner and the layout generally too specific to justify custom PCBs.
I think i’ll stick with perfboards for now, although i have no idea how i should wire all those stuff together.
When measuring mA, never adjust the dial (e.g. voltage, resistance etc.) with the leads plugged into the mA measurement points. It’s a low impedance measurement and you’ll blow the fuse if connected across a voltage source. But if the LED still lit up, then the fuse was okay. Maybe you were set to Amps rather than milliAmps?
If the PWM speed is fast enough, you should get an average of the current draw. Some meters also have a max/averaging function.
With my current design i’d need 4* DINX4 and 4* DOUTX4 when using direct connections between Btns/LEDs and SRs. For potentiometers i’d have an AINSER64. According to the docs double than that should be possible, but is such a large number of SRs going to negatively affect the MIOS32/Core32 performance?
On 20.3.2017 at 9:42 PM, latigid on said:
That’s right Peter, encoders should be directly connected to 2* DIN pins. With button/LED matrices it can work and does save lots of pins and power, but the additional wiring might be suboptimal. For instance, anything other than a clean, square array will mean rows will be split, but the columns still need to be wired together. Of course, a way around this is to create multiple matrices based on smaller sections, even if not all positions are filled.
Best,
Andy
Is it possible to leave some LEDs out (eg per row) in a matrix?
Could you explain “multiple matrices based on smaller sections” any further?
I’m really not sure if matrix wiring is going to be too tricky/messy with frontpanel perfboards in the end. I’ve to make the (large) frontpanel pcb out of smaller ones. I assume for matrices i’ll need some busses on these perfboards. But how will they fit in a space saving manner on a 2,54mm grid? Unfortunately i couldn’t find photos of similar projects on the web to see how others approach all this.
This is easy to test, just increase the number of shift registers defined in the NGC (max 32 I think), even if you have fewer in your chain. Now connect some hardware and see if you notice the latency. If you do, decrease the number of SRs until you’re happy.
Quote
Yes.
Quote
Instead of an 8*8 matrix, define two different ones, or however many you require based on the panel layout. You don’t have to fill every position.
Quote
Draw your panel, divide the thing into sections. Perfboard/stripboard is useful if you have regular 0.1" spacing, also consider the different heights of components and group those of a similar/adjustable height (e.g. LEDs are versatile).
I suggest that you go for the direct wiring route. It’s a much more linear way of solving the problem, and you’re not constrained by fixed geometries. It’s easy to address each element and to fix mistakes.
