Hi !
I’m starting my first MB Seq V4 with the BLM extension.
Now i got everything from SmashTV soldered and ready to implement into a box.
Of course i will first start to build up a case for the sequencer (..blm_scalar pieces are on there way..)
but this lead me to different questions :
Hardware
The main way to connect the Core32 module to the Core8 which drive the BLM is Midi.
You give here a third midi connection dedicated to the BLM (http://www.ucapps.de/midibox_blm/blm_connector_mbseq.pdf)
which, if i well understand, combine a Midi In & Out + the 5V Power Supply.
What would be the connection on the Core8 side ?
Connect midi in & out resp. to the core8 midi ports and power supply to J2 as proposed for multi-core powering (Midibox SID e.g.) ?
Software
* As i’d like to build a custom panel, i’m digging into the SeqV4 config file.
I’m not sure to exactly understand the addressing method of input & output.
I understand the pin number for each shift register, but not how shift register are numeroted..
Maybe you could light me on that !
* Also the BLM part of the SeqV4 config file is a bit confused to me :
why are we talking about shift register here ? is that not the job of the Core8 module ?
and so, why only 2 (or 4) SR ? there is 5*4 = 20 SR if you build the complete BLM_SCALAR Module …
I’m a bit lost on this point..
* To use BLM, i have to upload BLM firmware into the core 8. Any config ? i guess not if i follow the wiring schematic given by TK..
Ok i think that’s it for today ![]()
Thanks !
By the way, thanks to smashTv: kits are really well made, PCBs are great, everything is in there, and it’s quit cheap. very good job !
And also thanks to everybody around here, this whole midibox project is really cool! (i will not say it on every post but i mean it ![]()
Best Regards,
Thomas
