BankStick
Hello
My previous post looks like missing
Second phase of troubleshooting: Midibox does not detect BankStick. I am using Atmel402 24c256PI. When I am trying to copy current settings into bank stick it reports “No BankStick”. Very strange. As you understand it is very hard to make mistake to solder four wires Smiley Will try to replace flash chip with another one. How MIOS detects there is no BankStick connected? What sould be checked ?
Third question: I want to increase delay between button pressing. Contact bounce is really annoying. Where should I change the delay value ?
Thank you.
Hi Shar,
most people who reported problems with the bankstick just forgot to update their hardware to MIOS V1.7 - see also mios_v1_7_hardware_mods.html
To which pin did you connect the J4:SC wire?
note that this is an EEPROM and not a Flash
If there is no response from the EEPROM on a read, it will be assumed that it is not connected.
Schematic vs. your board, see http://www.ucapps.de/mbhp/mbhp_core.pdf
Which application are you using?
