Audioengine Controller
Hi KUI
I tested the LPC17 MMv3 with divers router settings.
I can’t follow the meaning of that router. I connected over J4B to MF_NG_v1_003
But what i discovered is that if i turn on Hot channel following it seams to ad 8 Channels as soon as I touch the Virtual fader with the mouse.
for explanation:
I fade my Hardware Midibox fader CH1. Then grab the mouse and fade the CH1 virtually with mouse. (Witch indeed doesn’t affect the Hardware faders…) and then grab my Hardware fader again and it suddenly fades the CH9…
Is it that what you mean?
Best regards
Ivan
Hi novski,
“Then grab the mouse and fade the CH1 virtually with mouse. (Witch indeed doesn’t affect the Hardware faders”
This is what I was refering to. It works fime in Mackie or LC mode.
KUI
Are you shure your Routings are correct? I still don’t see through those settings.
The node 8 you posed above is the way MIDI goes out but how does it come back to the MIDI Port 4 of LPC17?
I tried several settings but cant say for sure witch one is truly right…
Maybe a Pro Member of this Forum can answer this Question.
to repeat the above discussion:
wee have a MF_NG module on LPC17 Midi Port J4B (so MIDI4) and need to know how the Router settings have to be…
Thanks a lot.
Novski
Thanks a lot.
Novski
The return route should be" set router 9 USB1 all IN4 all "
I have tried this as well, no go for host to mmmv3 fader control.
KUI
Hi KUI
That gives out an error.
[990289.499] set router 9 USB1 all IN4 all
[990289.503] Unknown or invalid MIDI output port!
because second part is Output-Port.
[990646.533] MIDI Router Nodes (change with 'set router <in-port> <channel> <out-port> <channel>)
Turning it arround (like: “set router 9 IN4 all USB1 all”) is what you already posted earlier as Node 8.
I didn’t manage to get feedback from Host jet…
Hi KUI
[990646.533] MIDI Router Nodes (change with 'set router )
My mistake, I meant
set router 9 USB1 all OUT4 all
Still no response from the host. I am looking at the midi streams. SAC mm midi output does not match the midi output from Midibox MMv3.
I will ask BobL
KUI
Hi KUI
Did you ask Bob about the midi-feedback?
How is your project going forward? Does your device show the channel names on seperate displays?
Have a nice day!
Novski
Im now in Drawing progress of my MBHP_NF_NG and wold like to get some different thoughts…
My plan is to make Modules of 8 Faders, 2 Buttons, 8 OLEDS. One CoreLPC17 with a MBHP_NG slave.
I whan’t to connect several modules in a row.
Whitch Midi I/O should I use to Link the Multiple CoreLPC17 Modules and witch Midi I/O is best to use for Slaving the MBPH_MF_NG.
best regards
novski
