Audioengine Controller
Hi Pyjaman
Thanks for that advice. I that about that. But Live Music Business is a Ruff thing, especially to gear.
What if that wire falls off in the Truck that carries it to the Show Venue? I wanted to know “if” it is possible to flatten that a little bit IN the software to prevent of getting in trouble.
Do you Program by your own? Maybe you can answer me that… (I’m not practiced in Software at al…)
Best Regards
novski
Hey, you are the one building that thing, so you are in control. Build it in such a way that it can’t fall off! Simple!
Im just asking… “IS” it possible to flatten that in software?
“flatting” is the wrong term.
You are searching for a mechanism which filters MIDI events when the fader isn’t manually touched, right?
It’s provided with the touch sensor mode.
Once you connected the touch sensor, it would send a note event whenever the fader is touched (good for testing)
Now change the touch sensor mode to the option named “Like previous, but additionally no fader event as long as sensor not pressed” -> voila! :sorcerer:
Yes!
I’m sorry for the delay of testing that.
I now tested to contact the sensor T0 to fader number 1 and activated the “Like previous, but additionally no fader event as long as sensor not pressed” preset. And now it doesn’t tremble anymore.
Thats a solution to my question.
can you declare me what those other parameters are for?
  1. PWM Steps
  2. AIN Deadband
  3. MF Deadband
Thanks a lot.
who can explane me these parameters?
  1. PWM Steps
  2. AIN Deadband
  3. MF Deadband
Best Regards
novski
Hi.
  1. PWM Steps: This defines how fast the H bridge is ‘pulsed’ to control the fader motor. If you find that your motor is sluggish then you can adjust this.
  2. AIN Deadband: All A-to-D (analogue to digital) circuits suffer from a certain amount of ‘jitter’. The AIN deadband allows you to set a minimum amount of change in the analogue input before it is reported as a ‘move’ of the fader.
3: MF Deadband: I guess that this is the reverse of AIN deadband? only engage the motor if the input value has moved significantly. although TK will be able to confirm this??/
If you find that the faders are a bit jittery then you should be able to adjust the deadband values to counter it.
Cheers
Phil
Thank you philetaylor for that explanation on the functions of the GUI.
I now have a total different question.
I realized that i will not be able to ad more Faders than 8+1 in my approach because the Midi functions are restricted in this Program i use (softwareaudioconsole). The only Midi Template that provides more than 8 Faders including the Canelstrip functions is MotorMix. (i can’t assign Functions. Instead i select a fix Template file from the manufactory…)
noooow. my shy question now is: is it possible to transfer the MM Protocol from the midibox_MM to the MF_NG? :slight_smile:
is it possible to transfer the MM Protocol from the midibox_MM Project to the MF_NG?
Hi
I hope i get some answers because i can’t manage this alone. (And i try to keep my posts together because i don’t want to mess around in this forum…)
I finally decided to work with the MM V2 Application. Unfortunately SAC uses many functions by increasing the Rotary Selector Rotary. (well thats hard to describe witch one i mean… please, see attachment photo. )
So basically what i need to do is by pressing a Button i need a possibility to set the right Selection of Mode first.
So for a Sample: if i want to activate my Compressor i need to Virtually turn the Selector Rotary first to the “Comp Mode” and then press the Button 5. (in Normal use of MMv2 thats the Select Chanel 5 Button)
How can i do that in my Software? And is that Selector Rotary defined as “MM_VPOT” in the Application?
Thanks a lot for any Help
best regards
novski
edit: changed .tif to .jpg for easy view.
[SAC CM MM Help.rtf](< base_url >/applications/core/interface/file/attachment.php?id=9862)
im Searching for a Eagle Library Part TI SN74HC595N of the DOUT and SN74HC165N of the DIN Boards. Does anyone share them with me?
Thanks
I have problems understanding this part of code:
mm_id = ((led_id_l << 3) & 0x38) | led_id_h;
What hapens if led_id_l is: 0x41 and led_id_h is: 0x03
Thanks for help
novski
the operations perfomed are
0x41 is left shifted by three bits (aka multiply by eight), resulting in a value of 0x208
it is then ANDed with 0x38, resulting in a value of 0x08
this is then ORed with 0x03, resulting in a value of 0x0B
Hope it helps :slight_smile:
Bye,
Peter
Thanks Hawkeye! now i understand…
Do you speak German? (-i think i saw this video of you and Thorstens Jamsession…)
-Because maybe you can tell me why this tutorial talks of throwing the bits away by shifting…
http://www.c-howto.de/tutorial-variablen-bitmanipulation.html
thanks
novski
Hey there,
yes, speaking German :slight_smile:
Bitshifting just means, the bits are shifted to the left or right, and zeroes are added on the other end, in binary form on an 8-bit datatype:
11110011
<< 2
11001100
On many cpus there also exist instructions to rotate, inserting the bits that fall off one end of the value at the other end.
So a “trick” to throw the upper three bits of any datatype away, would be to shift left by three, then shift right by three.
But this is not necessarily the most efficient way to do it, that would most probably be by ANDing with 00011111 :slight_smile:
Many greets,
Peter
wow. interessting thaughts. Thanks Hawkeye.
I have a question about the
s32 MM_MIDI_Received(mios32_midi_package_t package)
Can i pause that in some way? I mean, stop the receive for a certain time…
Cheers,
novski
Well, may bee i have to start from the beginning.
As you may have read in this thread before I’m building a Midibox MMv3 on LPC17 Core. Thorsten was so courteous to lift it in to 32bit architecture.
But now I’m stucked in a problem.
My Controller simulates a MotorMix Hardware. This Controller has in reality 9 encoders. Eight on each Channel and one JogWeel for Menu purposes.
My Software can receive fixed Messages not so as most other programs where the user can program the Software-button to a Midi-value..
To control everything i need to jump virtually in to a Menu by increasing the JogWeel then i can select by pressing buttons according to a channel.
I managed to do that so far. And it works stable.
My problem occurs when i want to assign a LED to one of those Virtual Buttons… Because as soon as i reassume to default menu the LED doesen’t stay lit.
I found out that thats because the Feedback from the software, sends (of course) the new information for the Display and the according Buttons in the default Menupoint.
Im now searching for a solution witch recognizes the first feedback and sets the LED but ignores the following for certain time.
is that possible?
Thanks for any Help.
Novski
I tried to connect MF_NG, J11 to LPC17 Core, J5A Pin A6/A7 but can’t get connection to the PIC over Midi3 on Mios Studio.
pin “MO” to pin A6
pin"MI" to pin A7
(i tried to swapp A6 and A7 as well…)
Im runnign the MMv3 App
and have the default UARTs as this:
#define MIOS32_UART_NUM 4
I want to Link those two boards to communicate on one USB Port.
what is nessassary to define in mios32_config.h for that?
Im trying to set the Midi Merger over MIOS but always get this error:
[603998.955] set router <8> <IN4> <all> <USB1> <all>
[603998.959] Expecting node number between 1..16!
[603998.959] set router <node> <in-port> <off|channel|all> <out-port> <off|channel|all>: change router setting
The node number is 8. And so, between 1 and 16. Whats wrong?
(Running MMv3 on LPC17)
[603998.959] set router <off|channel|all> <off|channel|all>: change router setting
Hi Novski,
Proper sytax is
Set router 8 IN4 all USB1 all
do not use <>.
Have you been able to get 2 way midi with the mmV3 between SAC and the midibox core?
I have not been able to get 2 way midi with mmV3, ie I can move the physical faders and get the host software SAC to respond.
I can not get the SAC host software to move the physical faders without using MIDIOX and a virtual midi port in between them.
Any thoughts?
KUI
