asm to hex
Hi, I’ve got my hardware working but I can’t find anything on how to edit an asm file and save it as a hex. I’ve googled it and downloaded mplab and tried to follow the instuctions and got lost, can anyone point me in the right direction?
Hopefully this helps:
http://www.midibox.org/dokuwiki/doku.php?id=windows_toolchain_core&s[]=msys
also, what is your OS/MIDIbox app etc.?
I’m using windows 10 and have built a midi cv converter all the menus work but the Aout ng board needs to the asm file to be changed, this is where 'im stuck. thanks for your reply
I looked at the link but it not sure what I’m looking for?
I’ve built the hardware and programmed the PICs and loaded hex files from mios studio all ok but stuck on editing and saveing an asm file to a hex to load into the core.
You have to setup the build environment on your computer. Follow the instructions given on the wiki page. Then run MSYS, point the path to the directory containing your .asm and run the “make” command. This converts the coded file into a hex ready for transmitting using MIOS Studio.
You could also try the following:
< base_url >/topic/20192-a-guide-to-build-mios32-applications-with-eclipse-on-windows10/?do=embed&embedComment=175914&embedDo=findComment
not sure if it’s different for MIOS8.
Ive found the wiki page but cant find anything on a build environment? thanks for your help
I thought it would be simple to convert an asm file to hex but it appears to be out of my depth.
Have you done everything written on the page? Come back when you have.
Come now, don’t be lazy! You’re so close! Otherwise the MBCV will sit around wondering what it could have done with its life.
Been trying to use MPLAB followed some youtube videos to create a new project but when I try to build it I get the following
Debug build of project C:\Users\gra\Desktop\New folder\tes.mcp' started. Preprocessor symbol __DEBUG’ is defined. Sun Dec 10 12:08:04 2017 ---------------------------------------------------------------------- Make: The target “C:\Users\gra\Desktop\New folder\setup_j5_enabled.o” is out of date. Executing: “C:\Program Files (x86)\Microchip\MPASM Suite\MPASMWIN.exe” /q /p18F452 “setup_j5_enabled.asm” /l"setup_j5_enabled.lst" /e"setup_j5_enabled.err" /d__DEBUG=1 Error[105]   C:\USERS\GRA\DESKTOP\NEW FOLDER\SETUP_J5_ENABLED.ASM 95 : Cannot open file (Include File “src/main.inc” not found) Error[129]   C:\USERS\GRA\DESKTOP\NEW FOLDER\SETUP_J5_ENABLED.ASM 96 : Expected (END) Halting build on first failure as requested. ---------------------------------------------------------------------- Debug build of project C:\Users\gra\Desktop\New folder\tes.mcp' failed. Preprocessor symbol __DEBUG’ is defined. Sun Dec 10 12:08:04 2017 ---------------------------------------------------------------------- BUILD FAILED
Have abandoned MPLAB and read the
Quick Start Guide Toolchain Setup
I can load the asm file in wordpad and edit and save it but which program do I need from those listed to create the Hex file from the ASM?
I have downloaded docuwiki seems to be a collection of files, dont know what to do with any of them.
MSYS
I have MSYS, when I run it it brings up a screen like CMD but with a flashing $, don’t know what to do with it? thanks again for your reply, I’ve ltterally spent about 5 hours reading last night and 3 this morning going round in circles and feeling totally dejected as to how I cant do a simple task
in MSYS
cd %PATH%
is the command to change directories, where %PATH% is the location of your .asm
ls
lists the directories and files
cd can be run for one folder at a time, using ls to see what else is there
cd C: //opens C: drive
or as a path
cd C:\2487\trunk\apps\controllers\midibox\_ng\_v1
In your case, use cd until you are in the correct folder, then run make. If you have set up the dependencies and system variables correctly, your .asm will be used to build a .hex. If you haven’t followed the other instructions to setup the system properly you get no file and a list of error messages.
Thanks again for your reply.
I’ve called my asm file test and saved it straight to C drive to make it easier.
i then typed cd C: //
now after the green writting it says /c
so I think I’m at the C directory and i typed
make setup
but got the message
make: ***  No rule to make target "test. stop.
I suggest to unzip all of the files here http://www.ucapps.de/mios/midibox_cv_v1_3.zip
into something easy like C:\CV\
you would then navigate as
cd C:\CV make
perhaps you just have the asm in which case there is no command available. All of the subfolders (src etc.) are required to build a hex.
Wow thanks, that was it, I was just putting the asm file on its own. I didnt realise you needed the other folders
make has generated a hex file from my wordpad edited asm
I am so happy I’ve tried most of the weekend, thanks for your help and perseverance
this is the hardest thing I’ve done
building the midibox seq3 was easier
I guess I’m more of a hardware person thanks once again.
Graham
