Anyone need some motorfaders?
Hello,
Due to a design change in my midibox I have 6 of the
Panasonic motor faders left.  These were never used.
Here is what I have:
6 Panasonic Motorfaders  @ $7.00       42.00
6 TC4427 FET controllers        9.78
1 74595       .78
15 10k ohm resistors    .84
15 1N4148 switching diodes      1.80
24 1N5418 Schotky Diodes        3.77
10  .010 uf ceramic Capacitors   1.08
Total Parts: $60.05 US
Shipping: (Sweden, Israel, England)
Global Express 3 - 4 days  $30.00
Global Priority   4-6 days $15.00
If you have any further questions please let me know.
I am just trying to get what I paid for the parts back since I am not doing the motor extension.
If anyone is interested in them please let me know and we can arrange getting them to you.
Thanks,
Simeon amburgey
Sound Creations, Inc.
www.soundcreationsinc.com/midibox
Im in need of 8 motor faders, but i live in sweden.
Problem? How much do you want for them?
Does this faders have touch sensors?
What is touch sensors used for? :slight_smile:
/Pär
Hello,
You can email me privately with your mailing specifics and I will se what it will take to get these to you.
These are the Panasonic motorfaders which are not touch sensitive but Thorsten has made a great circuit available to accomplish this.
The touch sensitivity is useful when trying to change parameters while you have automation going.  it allows you to disengage the motor to make adjustments.
Hope that helps,
-verbose
-verbose
thanks for the reminder :wink:
However, here a schematic of the touch sensor circuit which will be supported with the next MIDIbox MF version. In theory it could also work with other MIDIboxes as cheap button replacement, but this will not work until I’ve added the special charging pulse signal at Port J14
http://www.ucapps.de/mbhp/mbhp_din_touchsensors.pdf
I also have the support chips and other parts for the MotorFader extension.
Thanks..
I may be dumb(probably), but how do i use this
circuit with the panasonic faders without toch sensors?
/Pär
Dont know for sure as I havent played around with it yet (I have the panasonic faders), but it would appear you only need to add buttons
Although the Firmware seems to detect when you move the fader manually and switch off the fader (without touchsensor track) not perfectly but pretty well.
Check first post in thread,
Thanks
