Antichambre "stuff and work"
Album by Antichambre
sammichSID
sammichSID - @ work
sammichSID
sammichSID
sammichSID - naked
sammichSID - off
sammichSID
sammichSID - that for Gui
I built this one for a friend. Ice and VFD version.
KPR77 - Disassembled
long ago a friend gave me this BAR, broken. Sequencer down.
Having nothing to lose, so I dismounted and download the schemas.
KPR77 - KLM-448 card
This card provides triggers inputs on CN07.
1/GND - 2 /CLAP - 3/CH - 4/HT - 5/LT - 6/ OH - 7/CB - 8/SD - 9/BD - 10/ ACC - 11/FLAM - 12/M1 - 13/M2 - 14/+5V
Mx=Metronome
KPR77 - KLM-414 the weakest link
Bye!
SammichSID - VFD filter
For the color filter, I used “Lee Filters”, after a little test with sampler.
I’ ve finally choose number 085 “Deeper Blue”:
[LEE Filters | Masters of Light - A Panavision Company"](lee filer number 085
KPR77 - KLM-414
An HDM20416 for replacement.
the card is already cannibalized. Square Leds, slide toggles and CN09 connector.
KPR77 - Drilling and cleaning.
The 29 3mm holes.
One led for each button.
KPR77 - > MB77 ?
MB77 under construction.
MB77 - Adding Leds
There is enough room between the lid and KLM-452 switches card.
MB77 - KLM-452 Board and DIN.
Originally, tactils switches were matriced, but the functions need DINs, so everyone on DIN.
I replaced some switches too. I have room in battery compartment.
Note: original power supply was replaced by a LM317 @6v and the switching system between battery and ext was removed.
MB77 - KLM-448 triggers input Board and DOUT.
Two HC595 to trigger the analog.
MB77 - KLM-415 MIDI I/O mods.
I replaced the two slide toggles on board KLM-415 by two DIN connector. And cut the plastic on the back (assembled during procedure)
MB77 - Ready.
MB77 - Closed.
Temporary labels during MB808 firmware modifications.
Left led and training toggle are Live function On/Off
Right led is tempo.
“CHAIN END” slider is Groove/Instrument encoder.
I don’t need tempo encoder cause it gonna work synched.
MB77 - New plexi window
e=3mm.
MB77 - New legend sticker.
Midibox Powered
MB-TIA Cartridge.
The original Atari Cartridge, broken E.T. game.
MB-TIA Cartridge. Under construction.
MB-TIA Cartridge.
8 bit Atari 2600 MIDI Fx Synth
MB TIA Cartridge v1
MB TIA Mecanical v1 PCB
A rainbow picture for Jaytee! :wink:
An old picture of the ili9361 driver testing, this 1,8" RGB TFT has 160x128 pixels, it is connected in SPI 4wires to the dipCoreF4.
The module cost 6$ at [buydisplay](https://www.buydisplay.com/default/display-1-8-inch-spi-128x160-tft-touch-screen-lcd-module-datasheet)!
SeqV4+ custom keycaps
I took this picture under the sunlight as you can compare their brightness with the others elements(screen, led matrix etc…)
MIDIbox Logo for your eagle Board
Re: sammichSID
Nice colors!
Re: sammichSID - naked
Nice!
what is the brand of the VFD?
Have you modified the driver for it?
Regards
Antix
I am interested, too - it really looks nice!
Yes i have modified the LCD driver.
Id=7 “custom LCD”, only for adjust contrast @ startup.
It’s a Samsung VFD, 4/8bits connection, model 20T202DA1E.
ith all features needed.The only difference is that contrast is digitally controlled.
Find on net @24€.
You can find if in professional audiovisual shop.
Or for a little stamp i can send it, a letter format is enough, and i bought 1 meter…
Regards.
Oh and…
Connection! 14 pins cause no led, only 5V supply 150mA typ. 220mA max. (no pots).
Thanks for the information - this has already helped!
Bye, Peter
Re: MB77 - Closed.
Awesome work! Maybe I should treat my VL Tone the same way?
Re: MB77 - Closed.
Great Midiboxification! :slight_smile:
Re: MB77 - Closed.
Thank you guys!
There’s some analogic mods to do with KPR.
ex: Bass Drum Mod.
Maybe it can be controlled by midi?
But for the moment, i don’t reopen it, i play it!
Re: MB77 - Closed.
so do i get that right, it has still the kpr sound in it?
awesome work!
Re: MB77 - Closed.
awesome work!
Thank you
And YES! It was the goal.
Some video? :wink:
It was not so difficult, Digital and Analog are clearly separated.
Re: MB77 - New legend sticker.
looks nice. how do you have these made?
This is just an eps file at this time.
With SidMonster, we are working on it.
With printing/cutting machine and metallic inks on adhesive.
gonna make a test and show result…
“illskins” coming soon…
awesome. i would like to do something like this for my ableton live controllers. i’m not big on the engraved look.
Re: MB-TIA Cartridge.
Nice job!
What 4-character display is it? Looks cool :slight_smile:
Greets,
Peter
Hi Peter,
My first intention was to implement a “mini CS” to change patch, bank…But i think it’s not necessary, I only use the MasMsp Manager. But I let encoder and 4Digit on definitive PCB, (yet designed), we are not obliged to put and use it and it’s difficult to cut squared hole in cartridge.
Maybe one day firmware will be an MB-link one!
You asked me for demo sound, you can find it on the blog!!!
Re: MB-OLRE16CS-a_v2b_eC_active view.jpg
Great stuff! Lovely routing :slight_smile:
/emoticons/fear.gif" title=“:fear:”> /emoticons/love.gif" title=“:love:”>
	1 hour ago, Phatline said:
		/emoticons/fear.gif" title=":fear:">   /emoticons/love.gif" title=":love:">
Don't be afraid you will love it ;)
I would like to show more about, but I've got strange behavior with pictures, for example this one uploaded in a wrong album...
