For the past week or so, I’ve been trying to learn my way around SysEx for the purpose of setting up a Behringer BCR2000 to program the sammichSID. After much trial and error, I have had some success, but I have hit a wall with the Voice Envelope ADSR.
Since Attack/Decay and Sustain/Release each share a respective address, I can’t sort out how to control them independently without issue.
Currently, I am using the BC Manager software (https://mountainutilities.eu/bcmanager) with the help of the SID Ctrlr panel to send the following data (for OSC 1 L/R):
*Edit* - I am sending a value range of 0-15 for each.
This gets me part way there, but I am unable to have independent control over them. If I move the encoder I’ve assigned to Attack, it will affect the Decay value as well.
I’m sure I’m missing something simple. Hopefully this makes sense to someone!
Thank you for reading, and any help is greatly appreciated.
Dhayv
PS - side question: in the hex above, what does the $06 $01 $00 represent? I have noticed it is included in almost every parameter I have come across so far.
unfortunately there is no way to change these parameters via SysEx independent from each over. In the Ctrlr Panel I solved this with some LUA scripting, but with generic MIDI controllers this will be difficult (resp. impossible).
If I’m understanding the manual correctly, NRPN (along with CCs) are non-destructive and won’t allow me to save any modifications (as a new patch, for instance). Is this correct?
If so, does that mean the only way to “destructively” modify ADSR parameters (and those with similar limitations) interdependently would be via the sammichSID itself, or the Ctrlr panel?
Thanks again for the help!
Dhayv
RE: the hex numbers, that makes sense and clears some things up for me. Thank you!!
Yes, you are right, NRPN changes are only forwarded to the edit buffer.
Well, there is an alternative firmware development kit available for the BC devices which should allow to implement this, but it will require some programming knowledge: http://willem.engen.nl/projects/bc2000-dev/
