Aditional Trigger Out
Hello,
i have a question please.
is it possible to use the aditional Trigger Outputs of the Core without having
a for example Analog Out NG or so connected?
How much Voltage is comming out of the Trigger?
thanks
Yes, that’s possible (depending on the app you want to use it might mean some coding [for the mbCV for instance the amount of coding = 0]), the triggers are 5V
it toke me a while to install the compiler stuff and so on… i use openSuse… now i do have headake, lol
just one more question about the *.asm file. is there anything else to change? i just want to try the J5
trigger Output within the Seqeunzer 3
thanks
;; use PORTA and PORTE (J5 of the core module) as trigger output
;; NEVER USE THIS TOGETHER WITH ANALOG POTS - IT WILL CAUSE A SHORT CIRCUIT!
#define DEFAULT_ENABLE_J5_GATES 1
Yep, that’s it.
thanks
