I have a question regarding an additional midi in port: I have seen the midimerger project and also the IIC midi that provide additional midi in for the midibox and I have seen that both use the RA4 port of the PIC…this is my question: If I use this port of my midibox64 for driving a 6n138 ecc connected to another midiin port, does it works or I need another PIC for doing this?
The MIDImerger project uses a software implemented UART which requires so much CPU time, that nothing else can run in parallel. So, it is not possible to use the same approach for any MIOS application - it just needs a second core which scans the second MIDI In.
A MBHP_IIC_MIDI extension would require some changes in the MB64 firmware. So, in theory this would be possible, but there is no ready made solution available yet
