adding 1 din and 1 dout to sm_c_example2_v1c
Hi to all the forum
I’m here after 3 years of stop! I’m very happy about the news on midibox ( stm32 and so on ) keep the community increase!
DIY passion bring me another time!
After all this years I’m considering build a midi controller for an old keyboard I get from a friend of mine.
Keyboard is from an old Italian manufacturer called CRB, it is not working but I’m considering to transform it to a midi controller.
This is my first and only problem.
All keybed are arranged in matrix 8x8 and I find that the application sm_C_example2_v1c work perfectly for me! ( I don’t need velocity or so on…)just for one keyboard.
I have only one pic core but a lot of din dout shift registers, so I wonder if is it possible to increase the application for manage 2 keyboards: in fact 8x8 uses only one din and one dout and I have available 4din and 4dout ( 2 complete din and dout module!).
I already look at 32x32 code and so on but they are coded with old toolchain and all in ASM, on the other hand sm_c_example2_v1c is easy because the code in ASM only manage the matrix driver and the main.c manage midimessages is in C and so I can reuse the main.c for adding pots or for adding other buttons for sending ( for example ) CC instead of note ON OFF messages.
Adding one 74hc165 and one 74hc595 can change matrix from 8x8 to 16x16 but this involved changing the ASM code: how can I do it using the same app?
Any help will be appreciated!
bye!
Andrea
