94 buttons in MB64e
Hi all,
Is this possible 94 buttons in MB64e ?
it is, but not with the original mb64e firmware.
instead, try this one and modify it yourself to fit your needs:
http://ucapps.de/mios/ain64_din128_dout128_v2c.zip
Ok, thank you
It is possible to support 64 additional button/LEDs assigned to static MIDI events by adding some code, but for your usecase the application proposed by Nasrudin is much better - it’s small and easier to customize (if really required).
I shall like having: 16 encoder, 94 Button / LED, 8 fader motorized
In my case , It is better to modify the MB LC
Thanks to you
Or combine following examples:
http://www.ucapps.de/mios_c_send_enc_rel.html
http://www.ucapps.de/mios_c_handle_mf.html
http://www.ucapps.de/mios_c_send_din.html
http://www.ucapps.de/mios_c_set_dout.html
