8 pots, 24 rotary and 32 buttons
To build a lower-cost midibox 64 with only 8 pots, 24 knobs and 32 buttons I understand that I need this:
1 AINX4
1 DINX4
1 DOUTX4
1 LTC
1 CORE
1 LCD
Is that correct?
Thanks!
1 AINX4 = 32 inputs with rotary pots or faders - so yes you need this
1 DINX4 = 32 push buttons - also need this if you want buttons
1 DOUTX4 = leds - not needed but helpful for button status & looks [glow=red,2,300]cool[/glow]
1 LTC = com port interface - not normally needed core board has built in midi connections
1 CORE = youll be wanting this one
1 LCD = optional but I would recommend it
watch out tho this stuff is very addictive
Thanks for the answer. I included the LTC because I thought it would be necessary for using banksticks. It isn’t, right? Are bancksticks connected directly do the CORE? I’m planning on ordering throught Chris’ site, because here in Brazil I’m having a hard time to find the parts, specially the PIC.
Another question: I understood that if I use motorfaders, I can only have 8 of them and I can’t have anymore pots or knobs. I’d also need one extra board for this to work. Is this correct?
Thanks for helping a novice!
Daniel
nah banksticks plug direct in to core board
Yeah the Motor fader module is like a seperate project it requires a core and a motorfader board for every 8 faders
eg I have one core, LTC, DIN, DOUT,AIN etc for my main midi controller then a further Core, DIN & motor fader boards for my 8 motor faders
The core must run seperate firmware to use motorfaders
hope this makes sence
Ok, I got it. So to have 8 motor-faders plus 8 knobs and 32 buttons I’d need 2 cores, each one with a different firmware. One firmware to the knobs and buttons and the second to the motor-faders. Well, I’ll build it with no motor faders. Too expensive for me right now! Soon I’ll have more questions!
Thanks!
Daniel
Just go for non motorised Slide pots, not quite as cool but still very effective.
