4-bit mode LCD mandatory?
Is it mandatory to have your LCd in 4-bit mode? I’m not using the CAN bus at all. I Remember disconnecting the 4 wires and losing the second line of my LCD. Do I have to bother with this if have no slaves?
Short version: Yes.
If your LCD won’t support 4bit, you can use other pins with Wilba’s 8bit driver… but the CAN buss pins need to be free.
Okay, I looked at Wilba’s PCB and found that it requires me to not use J5 if I want to use his 8-bit mode. Curses!
Actually, I cut the cables on the LCD and it appears to be okay. Though I’m not sure if my LCD is susceptible to the crash described in the document I found!.
Also I should note that I didn’t have the 1k pullup for a while now without any crashes on startup.
Edit: Thanks again for the info Stryd.
Don’t worry about crashing, worry about permanently frying the pins on the PIC due to short circuits. Follow the schem :slight_smile:
