The datasheet for YMF262 lists the chip requiring a clock of 10 to 16 MHz. Will it suffer if left unclocked, and should clock be established at the same time as the power supply?
Has anyone built a Midibox-FM without supplying a clock for the YMF262 chip?
This isn’t specified in the datasheet, but I think that the clock could also start later.
This won’t work, as the clock is used to generate the audio frequencies.
The OPL3 has no inbuilt oscillator.
Btw.: why are you asking? If you are planning to build a MBFM, the 14.318 MHz oscillator is required, otherwise the oscillator pitches won’t be correctly tuned.
