Yamaha MFC10
Hello!!!
I have a yamaha MFC10 midi foot controller that I use with my POD and g-major and to control my pc effects via midi.
I was thinking to convert it to midibox…
or
I have opened It and this foot controller have 3 board, a microcontroller board that have the power supply and a
custom made yamaha microcontroller and the midi in/out, a board that have 1 row of led and 1 row of switch,
a second board that have the 2nd row of switch and led, plus LED display and the buttons.
the 3 boards are connected with flat cable and all components are PDIP.
I was thinking to replace the microprocessor/power supply board with a midibox board with a custom layout
and to use the existing board to control the switch/led
i was thinking also to add a LCD to the main panel to display information like program name (better than the stock LED 2 char display)
and to mantain the existing LED 7 seg display to display program number (more visible on dark stages!!!)
I will keep you informed if anyone is interested with my progress
Cheers
Nicola Lunghi
ps
you can see information about this controller on:
http://www.yamaha.com/yamahavgn/CDA/ContentDetail/ModelSeriesDetail.html?CNTID=1158&CTID=#
“HEY YOU! YES, YOU! READ THE STICKY THREADS!!!”:
http://www.midibox.org/forum/index.php/topic,12845.0.html
“Please Read Before Posting New Topics: What is a “User Project”?”:
http://www.midibox.org/forum/index.php/topic,8954.0.html
Heheh, I was too slow :wink:
Yes please. From your description, it sounds like this box is a prime candidate for “MIDIboxification”… Once it’s more complete (code, wiki doco, build instructions, etc) we can move this thread back to the User Projects area.
I have opened the case and traced the schematic of the two board.
The board 1 and 2 use a flat cable to connect to the main board.
all the led on the two boards are connected to SN74HC374 octal D-latch.
the microprocessor put the data on all the devices simultaneusly and then
activate the clock pin only to the selected devices
or the bus structure is this:
8 bits shared between all 5 HC374
5 bits connected each to 1 HC374 clock bit.
this for led displaying. (i think that the led are always on or off… no strobing)
ah all of the bus bit are tied with a 10k pullup to +5V
for the switch, all the switches are grouped by group of eight
and are connected like this
              1K        diode            switch
+5V ----////-—>|-----------/___--------- common “read enable” bit of the bus with a 10k pullup to +5V
bit of the bus-----|
there are 3 of these “array”, one in the board 2 for the foot switches, 1 in the board 1 for the footswitches, and 1 in the board 1
for select/save/ etc etc the tiny button below LED Display.
For switch reading I think that the micro pull down the “read enable” bit, read from the bus and check the bit that have a 0
so the bus have another 3 bit for enable the 3 read switch array.
I was wondering if the ucapps main module have the required pin for all of this…
Is needed an
8 bit port
another 8 bit for control (maybe an encoder?? 3 bit to 8???)
5 adc channel for 5 foot controller
Serial In/out
perhaps… USB??
I think that I need to develop a custom board that have all "on board and fit the case
with all the opening and put midibox inside, or to leave midios and develop a custom firmware
Cheers
Nicola Lunghi
ps excuse me for my bad english…
ecco lo schema semplificato del bus…
