xoxbox panel definition files (fpd)
Sorry, I didn’t know where to post other than here…
I am currently looking for the fpd definition files for the xoxbox front and rear panel. I would like to oder some from Schaeffer AG but I don’t have the files in the appropriate format ! I would appreciate if somebody could help me out …
Cheers
orange
Moved to Miscellaneous.
The panel files can be found here (after 2 or 3 more clicks): http://tinyurl.com/6gzqaz3
Thanks Nils,
I have already used the search engine and can confirm that I couldn’t find the fpd fiels. There are some attachements in threads on the adafruit site but all files are in a different format. Or is there a possibility to convert EPS into fdp ?
Cheers
orange
If you poke around the treads you’ll end up with this blank panel for instance. Also, there’s some Illustrator files to be had, but those include 1/8 inch bleed.
Otherwise, there’s some dxf download available at Ladyada’s.
Cheers,
Google-fu
I think I have to do some conversion exercise from various formats into the fpd format. But thanks anyway, I thought I could save this step :slight_smile:
Cheers
orange
