[WTB] old LCD 2x40 w/ BL
I am looking for an old but NOS and/or working LCD 2x40 characters, HD44780 compliant to replace a dead one in a Roland D550.
That MUST be slim cause the old one had a t_otal thickness of 9mm_ (for example, the actual LCDs on ebay are 14mm)
It must have a backlight, a led backlight. no preference on colour.
Thanks for your proposals :slight_smile:
Hi Julien.
You probably already know this links:
http://www.polynominal.com/site/studio/gear/synth/roland_d550/lcd.htm
http://www.backlight4you.com/product_info.php/info/p926_EL-Panel–blue-green–21mm-x-166mm–laminated.html
The second is for use with a non backlighted LCD wich seems to be more common in this thickness.
Regards.
thanks fairlight, yes i’ve seen those, but the price for the EL foil is definitly a steal. My LCD is working, but i can’t easily read what’s written on without a BL. Moreover i would like to avoid the necessary cutting of PCB, drilling the case, etc.
So I am also looking for cheap EL foil replacemnt part ^^
