[WTB] IIC midi module
If anyone has an (unfinished is fine) IIC module in decent shape (no burned components or lifted tracks please :)) that they want to get rid of; I’m looking for one to add a Midi-in port to my MB6582 for the internal keyboard.
If nothing turns up I’ll just order a PCB and PIC at Smash.
I should be able to flash a pic for you. I’ll have to check tomorrow (i burned a PIC18F4685) to see if it is working. That way you should be able to do a low value order at smash.
I also got a PM from Rosch that he maybe has a spare PIC16F88 which should already have the correct firmware. I like cleaning out leftovers, and another look at the schematic revealed it’s so simple I’ll probably just build it on veroboard.
I’ll keep in mind that you have a burner though. Always handy :slight_smile:
P.S.
I have a 40 pin ZIF socket, real nice piece, bought it years ago when I still had plans to build a PIC programmer. Maybe you can use it on your programmer?
I bought this a couple of months ago. Goes nice with the Pickit i have. Thanks for the offer though.
oh i could use a ZIF socket! funny backlog traders, aren’t we?
That is exactly the same ZIF socket as I have, only mine is blue (which is much better for the bits ofcourse, everyone knows that :tongue: ) and not attached to a PCB yet.
@ Rosch: shall I put it in the box together with your PSU? Did you manage to test the 16F88 PICs you have left over?
Cheers, Alex.
I have PCB without any components on it (like new, i can give you one, if you want ! :flowers:
Hi Lamouette, is it a single IIC board or the quad version? Since I only need one extra MIDI in port a quad IIC board would be largely wasted.
i bought 4 IIC board before the Quad IIC was available, and i didn’t use them, so i can post one for you ! Just give me your adress ! Bye
PM sent :slight_smile:
cool! seems you got it solved?
if not, i’d send you the ones i have and you can check which are already flashed.
Hi Rosch, Lamouette was kind enough to send me a PCB, but afaik it is unsoldered, so I could still use a (flashed) 16F88 PIC :whistle:
(I’ll send you the ZIF socket anyway :flowers: )
